pandemonium123
- Ayrshire scotland
hi guys, im looking for some guidance and info,
i am going to start a multifuel "waste" water boiler project to be plumbed into the central heating on my parents house.
it is to be big enough to be filled every 8-12 hrs.
heat a house with around 20 rads, open vented system to run in parrallel with an oil fired boiler and have its own pump as well as being able to isolate it from the system.
control wise i was going to use this
http://www.regulus.cz/en/regulus-rt2-draft-regulator.html
and this
http://www.regulus.cz/en/for-overheating-protection.html#dbv
for regulation and protection
as for design
8-10" flue
6mm steel tube 900mm dia
3mm steel tube 1000mm dia
360 degree water jacket design
refactory insulated back plate with flue cut out, refactory insulated split front door with sight glass
whole thing 1000mm long
may install a back box at the bottom of the flue to creat an economiser using copper tube with detachable panel for ease of cleaning,
dou you think a water cooled baffle plate in the fire box in front of the flue be necessary?
something along the lines of a farm 2000 model or like this
http://www.dragonheat.co.uk/index.php
but on a smaller scale to burn wood, house waste, plastic, garden waste and so on.
i aslo like the design of these:
http://www.stevedowling.co.uk/dowlingstoves/id82.html
any pictures of yours will be helpfull
and this
as for design
8-10" flue
