Just thought I'd post a positive comment to balance all the negativity around the SIP range.
I've just finished replacing a full outer sill on a 1990 Mk2 Astra 5 door using my 12 year old SIP HandyMIG running 0.8mm SIP flux-cored wire and it worked like a charm. I'm very pleased with the results and the way the welder performed wasn't bad at all.
Anyone who says you can't weld with these things is being misleading. It's true that it initially required quite a bit of setting up (fitting a steel liner, greasing the spool holder, etc.) but once working it was a pleasure to use.
