I bought both mitre saw and the 185 circular saw last year and did post this on Echidna`s thread. Id seen the vid and decided to buy both. like i said before the little 185 saw has been verry good no complaints, but the mitre saw has been frankly rubbish with the blades not lasting at all. I phoned up evos technical dept up to have a moan and was told in no uncertain terms that the little 185 was designed to be used on steel but the rage3 was not but was designed to be a multi purpose saw but will cut steel. when i said thats why i bought it just to cut steel, unistrut angle, box etc they said i should have gone for the pro one! which is a lot of help now. anyway i have decided to buy the 255 steel blade(blue) next to see if its any better. their advert says that rage3 should get through 250 cuts in 50x2.5mm box. of the three blades i have purchased none have come anything near this I doubt if ive even got a hundred cuts out of it.
So chaps if your thinking of getting a rage3 just for hobby, diy metal cutting only remember its a multi purpose saw and not a dedicated metal saw as i have now found out.
