Hi guys after much research and trying to keep the cost reasonable ive bought a sealey mightymig 130xt, to use to build a basic off road buggy for my first project.
Although most of the work to be done is 1.6-2mm thick mild steel there is a few 5mm brackets that need to be welded together is this welder up to the job or have i just bought something that wont do the job???
ive seen conflicting information regarding this matter and was assured this could do the job (capable of 1mm-5mm) however ive seen a little review on this welder and it states 2mm thickness mild steel!
Also the edges of the 5mm joins are to be chanfered to 45degrees so prob a little less.
Has anyone used one of these or have any advice please, many thanks, Coll.
). They assume you will taper the joint and also that you will use (hotter) gasless wire if the machine has the ability to run it, and the last 1mm I can't account for.
