Hmm in what way, disolved/attack
How long were you using diesel, for that to happen?
And I was one of them. I just drained the parts cleaner to unblock the pump and found that the diesel had destroyed the cabling and even the paint. Wouldn't have taken much longer to create a short. I'm going back to water based degreaser,
It's the diesel with the bio-ethanol in it.....
What got up your japs eye?Diesel is diluted with Fatty Acid Methyl Esther FAME not ethanol.
Petrol is diluted with ethanol. Ethanol is ethanol - there is no reliable way to identify the production method. In the early days large quantities of ethanol produced from coal were exported from South Africa to Brazil. Brazil was the largest exporter of 'renewable' 'Bio' ethanol to the USA.
Not hard to work that one out.
Tangent completed - back to the actual topic. I find it difficult to envisage Diesel dissolving modern ploymers used for insulation, but I'm willing to be enlightened.
The cable to the pump was rock hard and cracking. The plastic of the pump itself was breaking down. I bought a new pump. The paint inside the parts cleaner has also softened and started breaking down. I've had the parts cleaner for a year.Hmm in what way, disolved/attacked it?
Yup mine is the basic parts cleaner.I suspect the cheaper parts cleaner are simply not designed to be used with fuel, as the official recommendation was citrus degreaser.
Look at how the little giant pumps workThe cable to the pump was rock hard and cracking. The plastic of the pump itself was breaking down. I bought a new pump. The paint inside the parts cleaner has also softened and started breaking down. I've had the parts cleaner for a year.
There's wiring, sometimes lots of it, in fuel tanks - both petrol & diesel.
It doesn't suffer from insulation degradation due to the fuel & it's additives, it looks like standard thinwall insulated wiring and probably is.
