Hello.
Lurked around on here for quite some time, I find this forum more useful than a lot of paint dedicated forums in all honesty.
I have an old 2000 Toyota Celica that is my project, I am restoring it and boy-racer'ing it. I used to play NFS Underground 2 as a kid and now I want to turn this car into the car I used to drive on the game - underglow lights and all that too.
I've been under the car and removed any surface rust with wire brushes and drill attachments. The car didn't require any welding and it was all superficial. So I then used rust converter on any spots where it was still knocking about, hit it with Zinc primer all over it then some Chassis paint. It looks quite nice from the underneath now.
I replaced the bumper with a Veilside fibreglass replica and the side skirts. I left the rear bumper but drilled some diffuser fins into the bottom with plenty of tiger seal, abraded and primed them.
I sanded the rest of the car down, took off the wing mirrors and spoiler, filled any minor imperfections and I am getting very close to painting.
I have a DeVilbiss SLG-620 as my primary gun with a 1.3mm tip, also have some cheapo HVLP 1.3mm as a spare, I also have a Fast Mover LVLP 1.3mm that I haven't used yet and have been considering it (my compressor is 100L).
My garage isn't the biggest and I think painting the entire thing in one go might be a little difficult so will be breaking it up into sections (i.e. roof, then the front wings, bonnet and bumper, then one side, then the other, then the back). Or perhaps a single panel at a time. I am not too sure yet.
Nonetheless, the car is originally Silver, but I wish to paint it in a solid colour - no pearls or metallics. I want it in RAL 5015 Sky Blue.
I am thinking of two options. In terms of durability, i'd like at the least 2 years out of this paint job before I have to look into messing around again with it. Ideally after a satin finish:
1. Buy some regular solvent basecoat & then use the Arc-Rite "Military" Satin Clearcoat (I believe this is the same as the ProXL range from the description). Or potentially the uPol S2085 "SMART" acrylic clear. I'd prefer a satin finish though because I am lazy and don't want to wet sand/polish. Possible 3/4 coats of clear per panel if I can.
2. Buy some Polyurethane Coach Enamel, thinners (whether it's White Spirit or Xylene or whatever the TDS calls for) and a very small amount of Terebine (Japan Driers) to aid with drying.
I know with both of these options, petrol/UV/weathering is an issue but I'd like it to stand up OK for around 2 years or so. And I am aware that if I go for the Enamel solution, there is pretty much no going back without stripping everything.
Out of these two options, what would you suggest would be the best course of action? Alternatively, what else would you suggest?
Thanks.
Thanks.
