Hi All,
New to the forum. I have a Hydrovane HV07RS compressor, last year for some time it was leaking oil badly through the motor seal and other gaskets. had to live with it as work was very busy.
We decided to have it repaired and serviced last October but were getting quotes £3K for the repairs, anyways we decided to take on the task ourselves. We ordered all the required parts/gaskets and seals, carried out the work following the workshop service manual , it all went great, cleaned the machine completely of all oil including flushing the radiator and pipes.
Started her up and it ran without any issues, ran up to pressure in no time. A few days after the rebuild it started to cut out after running for a while and after waiting for it to drain all the air it restarted again until the next cutout, this was not an issue before the rebuild service.
We are a small Motorcycle repair shop with a paint spray booth , we have water filters at all feed points, when working it does not produce oil in the air lines. This cutting out seems to happen more and more now so we replaced the Danfus Pressure switch a few days ago, it now lasts a bit longer before failure but does still cutout and needs to be restarted...very annoying whilst painting I must say, plus I noticed a little bit of oil in the air line.
Yesterday we removed all the panels and checked for leaks, no leaks anywhere, removed the oil separator to check for mayonnaise but it was clean with red oil only. The compressor is not used everyday or for real long periods and we do not have a air reservoir tank.
I would really appreciate some help in diagnosing this issue as it is causing major issues in the paint booth.
Many thanks in advance chaps.
Regards
Max
Regards
Max
