ISO 32 hydraulic oil, ATF will be fine if you don't want to end up with a container of oil you'll never use for owt else. Engine oil will work but SAE30 is a bit thick.
As penfold said, ISO 32 hydraulic oil would be best. Using engine oil instead of hydraulic oil can lead to premature failure of the seals so I would avoid that!
