stewart.d.campbell
Hi guys i am looking for advice on how to tackle fixing these holes-rot as i have not tackled this sort of thing before but got to start somewhere.The first bit is tucked under the outer wing a bit so if i want to cut it out im not sure what to use (air body saw) dont think ill get at it with anything else if even that.It has been patched before,I dont want to take the outer wings off if i can help it as they are good.The second bit is at the bottom front of the passenger inner wing and if you look closely you will see it has also been patched before and with corosion and help from me and a chisel it is now peeling off.The chassis leg is good even if it doesnt look great in the pic, after it was taken it cleaned up well so should i just cut out a rectangle and butt weld in new metal here, cheers for any help advice guys.
