Memmeddu
- Italia Sardegna
As a title
I would like to improve my welding and fabrication skills, not for work but just to take my hobby and my skills at an higher step
In my toolkit I have the capability to
stick weld using
7018 in almost every position , overhead I can but not as easy as in vertical or horizontal or flat position ,head , fillet,lap joint which are not a problem
6013 fillet vertical up and flat head joints
6010 in almost every position , just problems to control
Stainless also overhead but I don't use them often
Measurements with various instruments
I think that I can use an angle grinder because I have 6 or 7
Spark testing to recognize steel , stainless ,cast iron and different carbon contents (obviously not a computer)
Now one of my big concerns about welding is distortion , until I have an head joint I can control it relatively easy but when I have only fillets as for a bench leg starts to become a big problem to me
Another thing I'm always scared to blow through on everything less than 3mm thick , generally in this cases I use stainless 2mm rods but , sometimes is to difficult to weld
These are problems at the moment ,then there are also personal curiosity that I would like to know
So please can you give me some tips and tricks to improve my knowledge and skills ?
Thanks
Ps Remember that I have not to much time for various reasons , firstly my health because my kidneys so I can't press to much , second I have to work
stick weld using
Thanks
In fact the way you talk about welding on here, I'm not convinced you really know what the best rod is for each situation. Just a little bit of thought... and really, 6013 and 7018 will cover 99% of all general purpose carbon steel welding.
