There's a useful webpage, from a respected organisation, concerned with devices that may interfere with pacemakers:
http://www.heart.org/HEARTORG/Condi...erfere-with-Pacemakers_UCM_302013_Article.jsp
It gives quite long lists of electrical goods and devices which are likely and unlikely to interfere with pacemakers. You will need to click on the "Devices with Risk" and "Devices with little or no risk" headings to toggle the two lists.
Amongst other things, the article mentions:
"If you suspect interference with your pacemaker, simply move away or turn off the equipment. Your pacemaker won't be permanently damaged and will resume its normal activity."
In relation to arc welding equipments:
"Power-generating equipment, arc welding equipment and powerful magnets: Such as found in some medical devices, heavy equipment or motors can inhibit pulse generators.
If you work closely with or near such equipment, be aware of the risk that your pacemaker may not work properly in those conditions. Follow your healthcare provider's instructions about being around such equipment."
