adam_lambert
New Member
- UK - Bristol
I need to weld some solid 12mm mild steel rod to 3mm mild steel sheet (flat end of the rod to the flat of the sheet). I have been using a stick welder and can get welds that are strong enough but certainly do not look pretty. Stick welding around a small diameter tube and with thin plate is proving extremely difficult!
I have never used a mig welder before but managed to get a good deal on a Clarke 135te turbo from Ebay which I hope this will be more suited to this kind of job. The welder states it can weld plate up to 5mm thick so know there will be no issues with the 3mm sheet however I have no idea about whether it will penetrate the 12mm rod.
Does anyone have any idea whether this will work?
Thanks,
Adam
Thanks,
Adam
to the forum.
