It's just Mipa 2 pack epoxy primer.What epoxy primer? You should be able to find the spec sheet for it online that will advise overcoat time or curing times
I think I'll leave it until tomorrow before topcoating. Do you think I could get away without having to scuff it or will it not adhere right
dont think you can,2k epoxy then 2k primer wet and dry then paint
EP-Grundierfiller is sandable after 12 hours so definitely not overcoatable after that. And it says 30mins
Yeah it's the Grundierfiller stuff. I'm going to have to scuff it up now before I paint it with the enamel paint. I've never used enamel before so wondering how many hours between coats Is sufficient?
Are you sure? Everyone that I work with thinks that all the tech docs and manuals are just published to look pretty and use up spare trees.The manufacturer's TDS will tell you all that you need to know, that is why they publish them.
Paint I got is off a local company and there are no instructions on the paint and their website is very vague. I tried contacting them but no response. So I'm trying to figure it out"I've never used enamel before so wondering how many hours between coats Is sufficient?"
