Bought welder for $299 in effort to rust repair on car panels- was useless-either burnt holes or left ugly splatter & lumps. I was not expecting this- having used mig before (gas) as a welder employed, the difference here is the cheapy gasless welder. In fact, I achieved better results using stick!. So I r"earched on web & found prob- lack of gas!, 0.8mm fluxcore wire, no fine adj of wirefeed, only supposed 80 & 100 amp output, & only ac weld. I did following: fitted fan from s/h microwave oven which runs all time welder is plugged in; fitted inside a plugpack 12v modified by fitting a lm317 linear volt reg at 1.5 amp;using a 1k pot to vary feed volts to wirefeed motor from 8v to 13v dc; fitting 4x 25 amp full bridge rectifiers wired in parallel; wiring so wirefeed was neg & earth clamp pos. The tx prim winds are copper & sec winds are alum with flameproof insul- So now we have a much better weld & duty cycle has increased from 25% to maybe 75%. Having said all that - I would never recomend anyone to buy a gasless wirefeed welder - a stick m achine is far better- if buying a mig get a quality gas unit- or if can afford- a tig!.
