In PPC magazine they filled corrosion on the face of an alloy head with JB weld and then gave it a light skim. Apparently it worked.
I have some bevel gears from a diff. They have heavy scoring in the hole through the middle where they turn on a shaft which is also damaged. The shaft is cheap to replace but the gears are a bit expensive to get past SHMBO.
So I would like to fill the scoring in the bore with JB weld and then ream or hone it out to size. Would this work or would I just be wasting my time?
At the narrow end of the gear there is very little spare metal so I am not sure about over boring the hole and fitting a bush. If I did that would bronze be the thing to use?
i wouldnt braze it as u would need to heat it up to a cherry red for the rod to flow and would probably knack the gear wheel
if u made the bush it would only need about 50 though boring out of the gear wheel turn the bush outer diameter to suit gear wheel then make inner bore slightly under size . press in the bush then ream it out
