Just got my new welder.. And decided to upgraded EVERYTHING as well as shift from CO2 to Argon/CO2.
I now have a new regulator and have added a Flowmeter which I didn't have on my CO2 setup..
How exactly do you use it?
You can obviously control the flow out of the regulator into the Flowmeter.. But there is also a tap on the Flowmeter which will control the flow.
Which tap should you use to set the flow? Is it best to put lots of gas into the Flowmeter and then use the tap to restrict the flow.. Or is it best to try and get it right out of the regulator and then 'fine tune' it with the Flowmeter tap?
Or am I worrying about nothing, and you just use both until you get the right flow?
Also, for 95/5 Argon/CO2, do I want 10 Litres Per Minute?
Jon
Jon
