Hi all,
So I've got a project coming up that will require me to cut some 19mm thick aluminium to make a shape. My initial plan was to use an angle grinder, however, from what I've read on the internet and the tight inside corner I'd need to cut, I don't thick that's a great idea.
Now, I'm stuck trying to work out the best way to do it.
I thought about milling it, but don't own a mill nor do I really want one for a one-off project. I thought about using a cnc router of some kind, but apparently that's not a great idea. I've thought about using a plasma cutter but the hobby ones I've found only seem to be able to do a "severance cut" (not really sure what that means) of 12mm.
How would you guys go about doing it?
Before one of you inevitably asks, yes it does have to be 19mm (3/4 inch) unfortunately. Yes, I have thought about having it done by an outside shop (particularly by laser/waterjet cut) but the cheapest quote I've had is from a Chinese factory at $600 excluding shipping and import tax; which is insane for a part that's less that 6 inches long and 4 inches wide.
Not that I know anything about plasma cutting, but is it possible to do multiple "passes" with the plasma cutter, like 3 passes as if I'm cutting 1/4 inch material, let it cool down between passes to minimize warpage (I think there's inevitably going to be some, but these aren't precision parts so I'm not bothered if they aren't mill flat.
Any help would be greatly appreciated!
