you must remove the paint or the galvo with come out with black hard blobs..the zintec should be no problemHi
Has anyone used Zintec and then galvanized the metal. The galvanizer wants me to remove all the paint from the metal. I'm not sure if I need to remove the zinc from the repair panels made with Zintec.
Thanks!
the tricky A-post bits are made with Zintec sheet
How thick is this sheet? "A-post" sounds a bit automotive... It'll warp beyond recognition if it's thin sheet. 2mm will dip ok but any larger flat areas will still be prone to buckling.
If the zinc coating is just zinc, it should be OK. The galv place I've used don't mind dipping things that have bits that are galvanised attached.
Its a LandRover Defender bulkhead, I am prepared for some buckling of the panels but its worth it to stop it rusting again!
I have used 1.2mm and 2mm for my repairs but the original areas are 1mm:-)
