Gareth J
- North Cornwall
I'm in the middle of tearing down and hopefully rebuilding a really tired vane vacuum pump. It's just snapped a vane and jammed up. Should've used the special inspection hole to inspect the vanes and noticed they were worn to about 2/3 their nominal thickness, replacing them in good time... But didn't.
Everything is pretty worn, the vane slots and the bore. The wear ridge on the bore must be over 0.5mm and the bore surface is pitted and ugly.
I'm never going to make this a pristine machine but think it's worth chucking a £100 rebuild kit at it. A brand new pump is £850 though so 3figure machine shop bills are going to be hard to justify.
So I was thinking I'd just try to clean it up a bit, but with what? Hone tools are surely going to be too small. Bear in mind the bore is 2' long and the central ports are a good 2" across too.
Best idea I've got is just to get my arm in there with some wet&dry...
Any ingenious ideas greatly received!
