I'm after a new compressor for my new workshop, being single phase i'm struggling to get anything decent.
I currently have a Vtwin 3hp compressor with a 100l tank.
I was thinking about buying another 1 or 2 compressors the same and having a big auxiliary tank they all feed into. To make the tank I thought about using some 300mm pipe, 3-4 meters would give me 200-300 litres extra.
A rough calculation and my compressor seems to be about 4cfm-5cfm at 90psi. Rather than the claimed 12cfm.
I think with 12cfm and 300-400litres i'll have plenty of air.
I'm just wondering if something like this, would be better.
http://www.machinemart.co.uk/shop/p...ump/path/air-compressor-pumps-pumpmotor-units
But i've a feeling it'll only have the same output at higher pressures.
I've got a healthy power supply to run 3 x 3hp motors, but obviously I cannot buy a 9hp compressor because i'm single phase.
I did think about buying a pump like this. and using 2 x 3hp motors with 1 belt on each to power it. But I think starting would be a problem.
A couple of things I was wondering.
1. I know compressor tanks are relatively thick, but only to stop them rusting. If i use stainless steel to make the tank. 2mm should be plenty thick enough.
Has anybody made the own tanks? Without using propane bottles or something similar.
Has anybody made square tanks out of sheet metal? I'd imagine you'd need to make it very thick and brace it to deal with the pressures so it doesn't bow.
2. Am I better using 2-3 compressors, or 1 large pump with 2 motors. I like the idea of having 2-3 compressors with a large tank because if something goes wrong I still have air. I can also set them to come on at slightly different times to limit the surge.
