Big_Al_inSalford
New Member
hay guys.
I was on a job last night (not on the job...lol) and cutting a doorway into a container nicely when my plasma set just decided to give up the ghost.
As the title states its a hobart airforce 125 with a cebora ct40 torch.
the only symptoms i have is that the red light comes on after you push the trigger. the air works fine and if you touch the tip to a ground you will get a quick flash of the arc but then the red light until you reset the set. I have replaced all the torch consumables just to make sure its not that but the same fault stays there.
As I bought this unit second hand i have no instructions.
any help would be great as im at a loss to the cartoon pictures on the unit case.
BTW the air pressure is good @ 3.5bar
thanks in advance Alex.
