I used some high build primer today and just got a quick question. I used max meyer 5:1 with 10% thinners and the primer is very thick and it seemed it was difficult to get it to shoot correctly. The primer has gone on splattered, but this shouldn't be a problem as I have to wet flat the primer down anyway for basecoat. Is this normal that its so thick its very hard to spray (using a 1.8 nozzle)? I have used etch primer in the past and had no problems with that.
) you can at least start with the correct ratios and go from there.
