I got this machine just before christmas, I tried it before I picked it up and when I got it wire up just after christmas, everything was fine.
I've not touched it for nearly 4 months now and last weekend the HF start would not fire.
After scratch starting the arc a couple of times, the HF start began to work every time, so I suspected there may be some corrosion somewhere in the works. Also the tungsten kept getting contaminated and there was a white/brownish soot on the ceramic and workpiece. I'm using 8 l/min Argon and a 2% ceriated tungsten on clean mild steel
Today I decided to investigate a bit further, removed the side cover and found this.
I was expecting to see some sort of points setup but this appears to be a contactless system (if it is the HF unit) the blocks appear to be brass with some hard stuff attached to the ends and the green thing is a capacitor. I checked the gaps and one seemed to be a bit tight, so I removed the blocks and cleaned the faces. I then reset the gaps to .010" and lo and behold, the HF start now works most of the time and every time when warm.
However, I'm still getting contamination of the tungsten and workpiece after just a few seconds of operation. Since the machine side was still off, I got my mate to watch the unit when I struck an arc and it seems as though the HF is staying on all the time, even though HF is selected only for arc starting.
I tried using an airline to blow out the toggle switch that selects arc starting /constant but nothing has changed.
Can anyone tell me what I should be looking at next? I'm thinking that there will be some sort of timer relay to turn off the HF, am I correct and what might it look like?
Cheers, Mick.
Cheers, Mick.
