Will try attach pics ...
These are run of the mill type machine switches,all the sparkies will know them Im sure,one on other is an off type,both are spring loaded,when pressed in,they press out again when you take your finger off the button,,inside they both have 4 numbered 1-4 terminals,which I hope the pics picked up on my phone and also an earth,under the actual terminal block and another earth on the alloy case.Id like to wire them to a 240v motor,regular 3 core cable,so that green for on,red for off..The pics with the red stray wires are the green switch..if its possible, can someone tell me what terminal for what.
