I just got delivery of a new rtech 50 amp plasma on thursday this week and im having a few minor problems and thought id try here for some advice.
I wired it up to a 32amp plug and set the air pressure to 50psi as per instructions
It seems to cut fine up to about 35 amps.
Yesterday i cut up 2 8x4x 3 mil sheets no problem at all perfect was using the stand off spring.
Today i tried to turn the machine up to 50 amps and cut some 12 mil flat but it could not get an arc it just spluttered and would not cut.
Same story at 40 amps it could not maintain an arc with the stand off spring.
I took of the spring and turned the machine down to 35amps and it cut perfectly nice clean cut.
I then tried to cut a bit of 20 mil plate turned the machine up to 50 amps and it would not attempt to cut it could not maintain an arc.
Im thinking that their might be a problem with the pilot arc but im not really sure?
I watch the review on youtube and in the second video when he makes the first cut of the 19mm plate at the end of the cut the machine splutters. That is what my plasma does when i try to cut between 40 and 50 amps using the stand off spring.
Im thinking their must be a problem with it.
I like the machine it seems to be very well built and has a nice torch its exactly what i want so id like to solve this problem and get it working right.
All advice much appreciated
