Hi everyone
I haven’t welded anything for over 20 years and needed to make some additions to an old car trailer so I went to halfords and got myself a sip 140 arc welder.
On my 1st try things went ok once I got the hang of it I managed to strike an arc and put down a reasonably good weld so I got to work on the trailer half way trough the rods that came with the welder ran out so I started to use the packs of others that I got at the same time they was branded as sip so I assumed they would be the same but had loads of trouble striking the arc and when I managed to get it going I had difficulty holding it unless the rod was almost touching the only way to keep it going was to hold the rod really close (if im making any sense).
I had a play with the amps and different size rods but still the same result
Is this me or cheap rods or could the rods be damp or something I notices that the packs they came in have open tops and are not sealed?
As I say im just a beginner and assuming the rods are the same as was included in the welder box.
I was welding some light angle and box section using 2mm rods at around 120 amps
Any help please
Any help please
