Tin Can
Hi all
I have managed to get hold of a piece of plate 8mm thick and 600mm x 600mm which i intend to use as a small portable welding table top
As i am quite a newbie i was wondering if any one can shed some light on the following
1. How can i identify what type of steel it is to see if it would be suitable for the above job - we install the modern fancy cycle shelters that you see at modern hospitals/schools on behalf of a company that manufactures and sells them so i thinks its one of there pieces - it appears to be powder coated and if you wire brush this off it appears to be galvanised underneath so i am wondering what type of steel it is made of
2. Depending on the suitability of the steel would it be possible to remove the powder coating and use it as a small welding surface with the galv still on (i know about the safety issues concerning galv) but as i wouldnt be welding 'it' and only welding 'on' it would it be ok
I know the easiest answer would be to ring the company that manufactures the shelters but as i am not sure if it is one of theres and technically the plate 'fell of the back of a lorry' its a bit of a no go
Sorry if its a dumb sounding question
Mark
Mark
