540itouring
Hi , i am repairing some parts of my floor that has rusted on my jaguar xjs. I have drilled the spot welds out and removed the plate that mounts under where the rust has started. I will be making the plates to repair the holes and i have just made the first plate. I have put a step around the edge the same shape as the hole and i think it will be fine but would like to ask you first. I plan to mig weld this plate all around the edge taking care not to over heat the metal and was going to tack weld first to stop it moving. The sheet is approc 0.9mm thick and i have a ESAB Caddy C200i and you can easy set the metal thickness. This is new to me and if i am to weld around the edge of the 0.9mm new plate and the old floor is also approx 0.9mm would i set the welder for 1mm thickness or is it the thickness of the two plates added together even if i am welding the edge of the top plate to the top of the floor. Any advice please with thanks in advance.
https://skydrive.live.com/?cid=62092248A33A16EB&id=62092248A33A16EB!872
