I havent used a mig welder for a number of months. Switched on yesterday power got to the unit but when I pressed the trigger the wire spool didnt move. Looking at the bits that came with the unit there is a small low amp fuse but no where to put it from the outside. I can only assume the casing needs to come off and the fuse swapped out. Has anyone else found this to be the solution or can you think of any other reason why the wire no longer feeds throught. I've checked the tip and it isnt fused. The wire feed when running normally would make a sound but in this case it is deadly silent
thanks in anticipation
