Hi,
Just added a flowmeter to my armory and wondered what the best way to set the flow is. Should primary adjustment be on the Regulator or flowmeter? and in either case what ratios do you go by? e.g. should I set the regulator to say 40-50% then set the flowmeter at high setting or vica versa (high pressure, low flowmeter rate? )
Thanks, Carl.
Thanks, Carl.
I would do it like Gordon, you may get a burst of pressure if you set the regulator a lot higher than the flow meter.
