pidgeon chit welder
sticking metal since 1962
Help,
Any one with a decent Myford or such small lathe up for a small turning job ?
I'm looking for someone to turn me two small spacers / stand offs in 2 off brass , 2 off aluminium and 2 off soft stainless (total quantity of six )
size 8 mm long by 6 mm in dia with a 2 mm hole through them
ends of the spacer need to be rounded so they look like a liquorice comfit torpedo.
Also required two 10 mm x 12 mm spacers with a stepped hole right through ie
1 mm to the middle and at the other end a 2 mm hole to the middle ( yes I know they can all be done from the same end )
I tried to use the drill press but found that the drills wandered off centre
If you need the cobalt twist drills I can supply two of each size
I'm Willing to pay for them ..please PM me
David
David
