Hello right I bought this clarke 130, to do odd jobs on the cars, I got given some steel wire (0.9mm fluxcore) will this be ok to use on the panels if so what sort of settings do I need to use, I have tried to use the welder but I'm useless can't get it going also I have tried 0.6 copper wire and co2/argon and still not having luck, I basically for example get a bolt and sand the paint of the wing I then place the bolt on a sanded part and alms my touch between the gap and press the trigger but once it's done I can literally just push the bolt off the wing or if I'm lucky kick it off and it don't seem to get stuck, what can I be doing wrong,
This happens with both the 0.9 fluxcore and the 0.6 copper wire I use with co2/argon, all help appreciated, il try posting the front of a clarke 130 so you guys knows what setting I have to play about with I do want to use the steel fluxcore as my gas is nearly gone but I'm just practicing I can even weld a bolt to a wing so just want to get to that stage, all help appreciated
