633Squadron
- Manchester, UK
I am working to repair the Kilmak Fantom inverter welder and have identified out most of the major components on the circuit board; however, I need some help identifying two components that have me stumped and the RS Components search facility drew a blank about them.
The first is marked 'TA-316100' on the side and is a two-pin black ceramic package, approx. 20mm square x 10mm height with a hole in the centre. It's labelled TRF4 on the PCB. There are no other markings on the package. This might be a current inductor, as there is a failry hefty wire that passes through the hole in the centre and is soldered to tbe board.
The second is marked 'ULUS C28 3x500uH SM0204570' (or possibly 'SM6204570', it's faded and a bit smudged) and is an 8-pin black ceramic package with pins numbers embossed into the top. The package is 20mm x 18mm x 10mm height, but the top of the part is 'stepped' in by about 1.5mm on two sides, parallel to pins 1 and 8 (the pin numbering runs in a circle, 1 to 8 anti-clockwise). There is also a logo, possibly an arrowhead pointing to the right inside a circle. There is no discernible marking on the PCB to indicate what this is.
Any ideas as to what these might be, based on these descriptions?
