Hi guys ok i don’t have a set budget but I need some advise please. I can’t decide on a multi process machine or buying a new MIG and a new ARC with TIG function.
I’ve been looking at the ESAB Redel seems to tick all the boxes but Read some bad things so I’m really unsure now!! Any advice and recommendations are much appreciated.
What I will be welding mainly square box section with up to 5mm thick wall and up to 5mm thick plate and 10 mill mild steel flat bar for automatic gates and possibly some car body work and general fabrication. Currently have a Clarke 151en a sunglow 200A arc and the use of a esab buddy arc 180A I like all 3 machines but they are budget machines and I want something better thanks. EDIT to add that flux core would be a advantage so I can use mig setup on site sometimes using the stick is hard to get in under the gates so this will solve that issue
