whensparksfly
- ireland
any of you making your own car anti roll bar i am very interested to know what process you all use . cold beading the bar or heat treating the bar and what material you use.
there made of spring steel tortion barany of you making your own car anti roll bar i am very interested to know what process you all use . cold beading the bar or heat treating the bar and what material you use.
That is a neat trick. Both bars on my daily driver were made a similar way but tapering the ends (levers). As it's a big wafty barge i guess the idea was to give it a progressive rising rate in rollAnother trick if you want to make one from solid bar as opposed to tube and assuming it comes apart is to make the bar diameter bigger than you need and then keep removing material on the lathe from the entire centre part of the bar gradually making it weaker,
As i said they often require trial and error,
