owas
- Birmingham
Working on the bottom of my subframe,
There are 2 threaded inserts (M10) welded between the two spot welded halfs of the part, can't bolt it through as it'll interfere with another part that bolts on.
Both bolts snapped, tried welding a nut on, nothing would get them out so I figured helicoil time.
One side went perfect,
The other side not so much, the hole was ever so slightly off center so part of the bolt got left behind, meaning my 10.5mm hole for the tap ended up being too big once I knocked out the remaining thread.
What to do?
What to do?
