Kayos
Gone......
- North Lincolnshire
so why dont they make heaters with them. you cant get out more power than is put in
They do, air source and ground source heat pumps immediately spring to mind
This, and several other posts, seem to misunderstand how the machines operate.
No, they do not just take power for a minute and a half and then recirculate it. The element needs to run to raise the temperature of the washed items and then supply heat of vapourisation for some the water extracted during drying. The dried items are, of course, warm when the drying cycle is complete.
However most of that heat of evaporation is recovered by the heat pump, and used again. It works just like your fridge or freezer (but the heat extracted by the heat pump is returned internally, instead of lost from a radiator on the outside of the fridge/freezer).
I bought a ‘Bodge Self Cleaning Condenser’ machine (don’t know its model number). It has given no problems in the time we have had it and has simply had both the dry fluff filters cleaned each cycle, and the water filter washed through about every five cycles. Collected water could be used for plants - but is usually poured down the drain. Water is now a costly commodity to just pour down the drain - check it out!
I think it was about four hundred notes. Advantages are more than simply using less energy. I’m not sure it saves 80% over other types of driers, but certainly only uses about half a kilowatt (and not all the time, of course). It does take longer, so likely a little more fluff produced from the washing.
It does have a lower temperature setting, which obviously extends the drying time - but it still uses 500W of power when the heater is on. It cannot be as efficient as the faster drying because other electrical drives sre in operation for the whole drying time.
I would guess the energy savings exceed 50%. Depends on the system it replaced, I suppose - my old tumble drier was a condensing type, but energy was lost from the machine as warm air (but dry) and at least helped, during colder periods, to heat the house. Non-condensing machines would either preferably be vented to the outside or create an awful lot of damp air if vented inside!
The other main advantage, for me, is that my solar panels could certainly not support a machine requiring over 2kW of power (so more energy would be needed from the grid). With only a 0.5kW draw, the whole of that energy-use can be generated by my solar panels. Just need to choose when to run it.This is exactly the same reason why I use a 1kW kettle.
Can’t remember when it was actually bought, but it has certainly saved a lot of grid energy/cost during that time, with often half a dozen loads per week during periods of inclement weather. The washing line is still the cheapest, of course. A small closet with a dehumidifier would be a good option to employ, for drying clothes, etc (but we don’t have a suitable small room in our house) and would avoid the ‘fluff’ problem - but the heat pump drier was a good buy, IMO.
they nick em round our aeriaYou will laugh at this: But with rising energy costs - I have revamped our washing line - new line/pulleys etc:
And bought one of these to go under the car port.
Brabantia WallFix Wall-Mounted Airer
Buy the Brabantia WallFix Wall-Mounted Airer at Robert Dyas online. Free Click & Collect on this product or Free Standard Home Delivery when you spend over £30www.robertdyas.co.uk
like where . our drier is out in the cold so draws in cold airbe like vaccum cleaners with less powerfull motors that dont suck as hard to save electric. but it dont because it takes longer to suck the crap up negating the saving `
Nope. Definitely electrcity coming through those wires.Heat pumps generally use a refrigerant working fluid. Compress it, you get a hot side. Expand it, get a cold side. Moving heat, not making it.
The problem with heating is that it the cold side heat exchanger would ice up.
Gas is very effiecient for heating purposes. Conversion to elec is still poor. If your power comes from a gas fired plant you will now be using 2-3x more of Putins export.
Yeh, Bosch haven't seem to got it right this time. We opted for an AEG. You can access the condenser from the front of the machine for cleaning (even though it claims to be 'self-cleaning'.We bought an expensive Bosch one, it lasted about a week and broke, sent it back and bought one none heat pump for half the price. Look at the payback as now from talking to a repair man he told me many dont last long when out of warranty as they eventually clog up and its almost impossible to un clog them
With all the washing as well !they nick em round our aeria![]()
Here's how I've been cleaning out Whirlpool self contained condensing dryer for the last nine or so years ( water drain off plumbed high up in to the the washing machines waste drain pipe )Yeh, Bosch haven't seem to got it right this time. We opted for an AEG. You can access the condenser from the front of the machine for cleaning (even though it claims to be 'self-cleaning'.
