many_methods
- Croydon, UK
Hi,
I've finished building a wood burner using an old gas cylinder (15kg size). However, I've heard people say that they don't last long as a few good fires can cause the thin metal walls of the cylinder to corrode and burn through.
To compensate for this I was planning to line the inside of the cylinder with a 5-10mm thick layer of fire cement. Slop it in, skim it as smooth as possible and then fire it up to make it set.
I realise this may only help to delay the inevitable burn through but does this method sound sensible?? Should I be using a thicker layer of cement? Do I need to spend much time prepping the metal before adding the cement?
Open to alternative suggestions. Others have mentioned filling the bottom of the cylinder with sand which I'm also considering. I'll also try to avoid having the fire too fierce.
Cheers
Cheers
