Hi!
I need to do some welding on the backside of a poslished stainless steel sheet (welding on a bracket). The question is now; will I be able to polish the heat stains away on the other side (visible)? I think it's solid enough to not have the bead penetrate through to the polished side. If it does - well I'm fxxXxd anyway
Resp. how would you do this? If the bead should penetrate through (it's 1.5mm IIRC), how would you rectifie this? Grind back with ever finer coarse & re-polish? Would this be possible? I've never had to do any work of this sort before...
Thanks for your suggestions!
Jan
Jan
The clamps are 1mm galvanised steel.
