gaz1
- westyorkshire
no as you still need your mainboard g/card drivers and windows disc's only use basic ones
a winborg disc dosnt it has loads of other drivers with the disc for both intel and amd
for the older systems like xp that are still in use today, a winborg xp disc is an advantage to many users the only issue that still stands is the gcard driver but there is still copys of it on the net.
install video is like the below video for xp
theres winborg xp sp1 - sp2 and sp3 versions out there
windows 7 is also the same the best disc to have is a winborg disc it is better than the windows legit disc but you will still have to find the gcard drivers
theres winborg 7 and winborg 7 sp1 does exist
winborg 7 disc allows you to build a usb install version
with the winborg discs ive found that i didnt need to find the mainboard drivers as it comes with the disc the only main driver ive ever had to find has always been its gcard driver for that operating system wether it being a base unit or a laptop that ive installed it upon
laptops usually needs the camera drivers and also the gcard driver as the winborg disc works the same as a normal windows install
