BrokenBiker
- Newport, South Wales
afternoon all.
just had to spend some time under the car, and it really made me wish I had a lift...
no space for a lift though, so I got thinking, has any one made a jack that is positioned on the wheel?
in my mind I can see a rectangular frame that fits around the tyre, a scissor action with a 2 tonne hydraulic jack fitted, 4 in total (one for each wheel) all connected to one hydraulic pump so they all elevate at the same rate/time.
now, you jack the car, or drive onto the frames if possible, and then use these 4 jacks to lift all 4 corners to a suitable height where you can put it on stands, or even leave it on the jacks if you can provide a good fail safe incase a pipe splits under load.
I can see this being very handy, and if you need to remove a wheel you can just replace that corner with an axel stand in the relevant place.
this would provide a level car to work on, plenty of space underneath to lay comfortably and manoeuvre around and just generally make life easier.
anyone seen anything similar to this before?
