The dual speed motor is 2 1/2 and 5hp, you would need a very expensive convertor or inverter to run that.
Even the 3hp looking over a grand to power it, its the startup current that kills em.
I run the coolant motor off my inverter with no problems also.
The less expensive inverters like mine require to be hard wired to the motor, bypassing all machine switches contactors etc. You then re-wire the switches emergency stops to act on the low voltage controls to the inverter. Not too difficult if you know what you are doing and drives direct will give you guidance.
Manuals useless 100 odd pages blinding you with science.You will loose all existing lathe functions, emergency stops, foot brake, spindle stop/start, lighting etc. plus the coolant unless you can live with variable dependant upon the motor speed.
How on earth do you run 3ph coolant pump at a steady pace?
As far as i am aware the voltage varies dependant upon the pot setting. Meaning if spindle speed is altered you would constantly keep having to alter the flow.
My coolants dual voltage but 3ph 3HP motor is not.
Originally took a flyer on Stormins inverter it just puts out 220V no good like me having a non dual voltage motor. Look far easier to configure and wire than MA7200Manuals useless 100 odd pages blinding you with science.
Would have been far cheaper to buy new motor.
I was mis sold the second time by above name having to lash out on an MA7200 plug and play 4KW. All i was told was to wire direct to motor and figure out the wiring for myself after many months.
could i change it to single phase then or put a simpler 3 phase motor on it
how much would a 4 hp moter and inverter cost
what would happen if i downsized the motor to lets say 3 hp
So which motor have you got in at the moment the single speed 3 hp or twin speed 2.5 / 5 hp?
By putting in a 3hp motor you wouldn't be downrating the machine, the 5hp motor uses the extra power to spin faster, powering two sets of windings.
Single phase motors do not last as long as three phase motors and don't like stop start actions, soon ruins the capacitors. The also don't give as good a finish to the machined face as they don't run as smoothly.
Bet thats wired direct to the motor doing away with all the controls and coolant.
A 5.5hp plug and play inverter lasted 1 1/2 hrs £650 thank you, good bye. The startup current is equivalent to starting a 9hp motor!
Soft start has no function just delays the relays and contacts tripping in, once tripped in its full hard start.
I have a 4KW rotary convertor as back up, put a cut on spindle slows and judders with a 3hp motor. Ok for pissy cuts 2mm.
How much would the performance be down if i swapped out the 5hp motor for a 3hp one and ran it off a vfd ? The lathe is a colchester master 2500 , i have no need for huge cuts or massive speeds really.
A 2mm cut is fairly big for 3hp, if you want heavy cutting capacity you will need a bigger motor and pay accordingly.
