R rossk76 New Member Messages 6 Nov 28, 2012 #1 Need to build up some worn out universal joint ends that run on bronze bearings, can any help with filler rod recomendation? Would it be a normal process or will i have to pre heat before hand?
T TechnicAl Banned Messages 8,779 Location Rotherham Nov 29, 2012 #2 Usually the bearing are sacrificial so providing the other face is harder it should be fine. Therefore you could use mild steel
rtbcomp Moderator Messages 18,548 Location Sheffield UK Nov 30, 2012 #4 I had a clutch in my Progress Drill repaired that way with tig.
