Hi Guys,
First time on ya forum, I have a Hanshen 40 plasma pilot arc type (cheapo £375 from ebay) I've only used about six times. First off worked ok then tips kept burning out. Supplier replaced complete torch assy and it worked ok for a couple of times then same problem. Max steel thickness cutting is only 3mm
It now only arcs from the side of nozzle and dances around, even with new tip and nozzle fitted. Any ideas please
cheers Mick newbie
cheers Mick newbie
are you sure that the torch is getting air when you trigger it? I ask as I forgot to turn air on once when using mine and got the same kind of effect....
