Hi,
I've yet to start on the thin stuff on my Viva (floor section mostly.) But my limited experience on the now-scrapped BMW was it was all too easy to blow holes even on the lowest setting (25A on my SIP.) I've now watched the 'pulse' technique video and, maybe with more experience and the wire-feed issues sorted out, I'll find it easier.
But I'm still pondering something. It's a single-phase welder with a centre-tapped transformer secondary using a pair of diodes for full-wave rectification. So, by replacing one of the diodes with an SCR I could 'switch a diode off' hence switch between full- and half-wave rectification.
I'm kinda "thinking out loud" here... So, instead of 100Hz pulses of DC, I'd have 50Hz pulses, missing every other pulse. Could this make it easier to avoid putting too much heat into thin car-body steel or am I barking up the wrong tree?
I can try it out (when it stops raining...) by disconnecting one of the transformer secondary connections but I thought I'd run this past those with more knowledge/experience first
Cheers, Kat
Cheers, Kat
