julianf
- devon, uk
I have been asked to build an air powered cannon to shoot squash balls from a bike pump.
Its a very simple device - a 42mm copper barrel, some end feed copper fittings, valves etc, but then the accumulator is a bit of soil pipe - this is the bit that concerns me.
The copper end feed stuff will be rated to 10bar plus, as, of course, its main purpose in life is to carry pressurised potable water, however, soil pipe is not specifically designed to be pressurised.
So, my question is -
Is this then unsuitable at any pressure (as its not got a rating) or is it a case of "If its tested to 6bar, it will be safe at 2 bar" - what about cumulative damage?
Or should this part be removed entirely, and replaced with somthing that is rated to higher pressure (eg wide bore mdpe water pipe - rated to 12 bar)
The idea of this item is to demonstrate (ie staff use only) trajectories etc in physics classes, but it is essential that it can pass the risk assessment rating, otherwise it can not be used.
Thank you,
Julian
Thank you,
Julian
