mike os
just a little insane.....
- North Wales
Need one or the other or both... but cant do both now.
so, assuming I generally work in thin stock... say 1-1.6m will plasma give a good enough edge for most situations assuming that it is not exposed... ie turned over/welded? ( assuming using a guide and some edge dressing but not excessive)
Or do I really need a guillotine to get it right & plasma for later?
my feeling is a guilotine is OTT for my needs, but if I am going to spend forever cleaning up then maybe not.
Thoughts on adding a guillotine to a hydraulic press?/bender (yes it is nearly finished
) ( non commercial use
) I have 32ton/m available, only question is do you think it do-able & where to get/ what to use for blades? (either pivoted at one end or 5 deg rake for shearing edge)
