It all depends on the profile you're cutting and also the thickness. Like Baz says, the 1mm discs are very good although they don't last many cuts.
What sort of stuff do you need to cut?
I use a grinder all the time, with a 1mm disk and a steady hand you can happily cut a line that is <1mm away from where you wanted it, indeed better accuracy than that isn't hard.
Dropping a straight cut through box section takes a bit more care - but then if you can't do it you could mark all four sides and rotate and cut each one.
