Hi!
I'm having a weird issue with my welder... I was welding last saturday, all was fine, used my std. setting for sheet metal.
Lvl 2 of 8, wire at 16 to 17 out of 99 (digital gauge) for but-welding, lvl 3 for plug-welding. Güde MIG190 - 200 Amps max.
However, on monday, I didn't get any penetration at all, welds were high, blobby and 'cold'. I had to use lvl 4 & 5 for welding, but even then penetration was bad and many welds turned out 'cold'... Sheet was 1mm! Unless US cars use something thicker/thinner? Was a '98 Jeep.
And also this happened some times:
I cleaned the earth clamp, I changed the contact tip, tried to play with wire speed - to no avail... I noticed that the welder was 'humming' whilst welding. And the trigger on the torch sometimes does nothing - could this be the problem? A 'trembling' trigger!? I've cleaned the trigger contacts, but nothing changed. Weather was very(!) humid that day - could this affect welding this much!? I was welding outside.
A very frustrating experience... :-/ And I'm somewhat clueless... I tried to position the earth clamp as close to the welding as possible.
Any hints? Thank you!
Regards,
Jan
Regards,
Jan
But I rather not touch any high-voltage wires, knowing my electricall skills *g*
