Quietcountrylad
New Member
- Ireland
Hi , just seeing if I can get some info re screw type car lifts / ramps.
I bought a used Werther 253 screw type car lift / ramp ( built circa 2000 ) a few months ago. Ramp was bought as a non runner from a main dealer for reasonable ish money. Have previously used a Chinese built hydraulic two post lift , I'm unfamiliar with screw type lifts.
Known issues ; bad motor
Possible issues ; was told lift nuts may need replacing.
Plan ; check for wear on main nuts , replace 4KW three phase motor with a single phase reversible 750w motor and reduction gearbox from a winch ( she'll be slow )
Ramp is now assembled and ready to test.
Wondering how best to test if the lift nuts need replacing? And what's the allowable wear limit?
Also the screws do not rotate by hand , presumably due to a mechanical break , how is this released for testing? And how to check if it's in good working order?
Also anything else that needs checking on this type of lift?
Thanks again
Thanks again
